Jhunclaudio_106
Aug 31, 2009iRule to match on the URL and then perform encryption and send traffic to designated web servers
I am new with Irules formulation and i have a requirement base on the subject.
I have a current virtual server acceppting HTTPS from the internet and redirect the web traffic via HTTP in my http pool. but a new requirement to protect the customer information communication from BIGIP 8800 to our Web servers by redirecting customer login URL to our WEb servers via HTTPS using https_pool. How can i achieve this requirement using the existing virtual server.
Many thanks in advance for your time looking on my issues.
- L4L7_53191
This shouldn't be a problem. Have a look here for some of your options: http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=14536
In particular, look at hoolio's first example which shows you how to selectively disable ssl (you can just as easily *enable* it as well) based on uri:Pasted from http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=14536 when HTTP_REQUEST { Check if request matches the criteria to disable server-side SSL if { [HTTP::uri] starts_with "/clear"}{ disable SSL on the serverside context SSL::disable serverside select the http pool pool http_pool } else { default is to use server-side SSL and the https pool pool https_pool } }
Be sure and read the whole thread as it's got a bunch of good stuff in it and it'll give you a feel for some of the options available to you.
-Matt - Jhunclaudio_106
Thanks Matt for the response, I will try to create an irule that have a similar setup and do testing.
Give you feedback on the result.
Regards
