dgytech's avatar
dgytech
Dec 15, 2017
iRule to exclude specific URI from http header insert (x-frame-options) on http_response
Attempting to exclude two URI from a http header insert on a HTTP_RESPONSE. Basically if the URI contains "/wp-login.php" or "/wp-admin" i do not want this header applied on the response.
I was previously inserting the header on all http_response: (old)
when HTTP_RESPONSE {
     HTTP::header insert X-FRAME-OPTIONS "SAMEORIGIN"
I now need to exclude two URI from receiving the header: (new)
    if {     ( [string tolower [HTTP::uri]] contains "/wp-login.php" )
     or ( [string tolower [HTTP::uri]] contains "/wp-admin" )
    } then {
        set insert_x_frame_options 0
        set insert_x_frame_options 1
    if { $insert_x_frame_options } then {
        HTTP::header insert "X-FRAME-OPTIONS" "SAMEORIGIN"
My (new) irule does appear to be working however, i wonder if there is another/better way to accomplish this.
I assume you can not apply "IF uri" logic to a http_response clause. Something like:
set low_uri [string tolower [HTTP::uri]]
if { not (
            ( $low_uri contains "/wp-login.php") or
            ( $low_uri contains "/wp-admin" )
} then {
I hope this makes sense, any assistance/thoughts would be appreciated. Many Thanks!
  • You were almost there!
    Unverified and not tested for syntax errors, but this should work. 🙂
        set uri [string tolower [HTTP::uri]]
        if { $uri starts_with "/wp-login.php" or $uri starts_with "/wp-admin" } {
            set xins 0
            set xins 1
        Also verify that the xins variable exists
        if { [info exists xins] && $xins } {
  • Lots of good answers above.
    Just to explain the logic of the required structure reflected in the above irules ...
    HTTP::uri is not valid in HTTP_RESPONSE
    Valid Events:
    ASM_REQUEST_DONE, CACHE_REQUEST, CACHE_RESPONSE, HTTP_CLASS_FAILED, HTTP_CLASS_SELECTED,
    HTTP_PROXY_REQUEST, HTTP_REQUEST, HTTP_REQUEST_DATA, HTTP_REQUEST_SEND,
    REWRITE_REQUEST_DONE, SERVER_CONNECTED
    So you need to set a flag in HTTP_REQUEST that controls the HTTP_RESPONSE action. I hope this helps.
