NickAD's avatar
NickAD
Icon for Cirrus rankCirrus
Apr 13, 2017
iRule to block string in header and display blocking page
I am wondering if I can create an iRule to block a request if a certain string appears anywhere in the header.
For example, it would be something like...
if { [HTTP::header "User-Agent"] contains "test1234" } {
drop
return }
Except I would not want the block to be limited to the User-Agent. I would want it to be blocked no matter where "test1234" appeared in the header.
A follow-up to that would be if I can also have this iRule display the blocking page with a SupportID. I would like those testing to be able to have visual confirmation to see it worked and so they can easily share it with others.
  • I have never tried this but you may be able to get something along this line working:
      foreach header_var [HTTP::header names] {
        if { [HTTP::header header_var] contains "test1234" } {
          drop
          return }
  • Snl's avatar
    Snl
    Try below
       log local0. "[IP::client_addr]:[TCP::client_port]: User-Agent: [string tolower [HTTP::header "User-Agent"]] requested [HTTP::host][HTTP::uri]"
          if { [string tolower [HTTP::header "User-Agent"]] contains "test1234"} {
      log local0. "[IP::client_addr]:[TCP::client_port]: Rejected request"
      reject   }}
