nastymatt_11986's avatar
nastymatt_11986
Feb 21, 2013
irule to a pool using SSL
What I am trying to achieve is to send traffic to a specific pool based on the uri. Which works fine on http, the issue I have is when I use the irule on https.
I have to assign an http profile to enable me to add an irule, when I add the standard http profile we have the site browses very slowly or gets connection time out. I am assuming I need a different setting in the profile or + ssl profile (server).
Does anyone have any info on what the settings should be in an http profile (to allow ssl to work) or pointers to it? (FYI - if I add the http profile with no irule it does not work - so it's not the irule).
thanks in advanced
