Patrik_Jonsson's avatar
Mar 27, 2021
Solved
BigIP Controller for Kubernetes not adding pool members
Good evening
I'm trying to get the BigIP Controller up and running in my lab with CRD's but I can't get it to work. Gonna try to give the information needed for troubleshooting but please bare with me and let me know if I missed something.
The situation is like this:
The controller talks to the F5 and creates the Virtual Server and the pool successfully, but the pool is empty.
I used the latest helm chart and running the container with the following parameters (note that I did not use the nodeSelector option, although I tried that too):
        - --credentials-directory
        - /tmp/creds
        - --bigip-partition=rancher
        - --bigip-url=bigip-01.domain.se
        - --custom-resource-mode=true
        - --verify-interval=30
        - --insecure=true
        - --log-level=DEBUG
        - --pool-member-type=nodeport
        - --log-as3-response=true
Virtual Server Manifest:
 apiVersion: "cis.f5.com/v1"
 kind: VirtualServer
 metadata:
   namespace: istio-system
   labels:
     f5cr: "true"
 spec:
   virtualServerAddress: "192.168.1.225"
   virtualServerHTTPSPort: 443
   tlsProfileName: bigip-tlsprofile
   httpTraffic: none
   pools:
   - service: istio-ingressgateway
     servicePort: 443
TLSProfile
apiVersion: cis.f5.com/v1
kind: TLSProfile
metadata:
  labels:
    f5cr: "true"
spec:
  tls:
    clientSSL: ""
    termination: passthrough
    reference: bigip
The istio-ingressgateway service:
kubectl describe service -n istio-system istio-ingressgateway
... omitted some info ...
Selector:                 app=istio-ingressgateway,istio=ingressgateway
Port:                     status-port  15021/TCP
TargetPort:               15021/TCP
NodePort:                 status-port  32395/TCP
Endpoints:                10.42.2.9:15021
Port:                     http2  80/TCP
TargetPort:               8080/TCP
NodePort:                 http2  31380/TCP
Endpoints:                10.42.2.9:8080
Port:                     https  443/TCP
TargetPort:               8443/TCP
NodePort:                 https  31390/TCP
Endpoints:                10.42.2.9:8443
Port:                     tcp  31400/TCP
TargetPort:               31400/TCP
NodePort:                 tcp  31400/TCP
Endpoints:                10.42.2.9:31400
Port:                     tls  15443/TCP
TargetPort:               15443/TCP
NodePort:                 tls  31443/TCP
Endpoints:                10.42.2.9:15443
Session Affinity:         None
External Traffic Policy:  Cluster
Events:                   <none>
The pod running the gateway:
kubectl describe pod -n istio-system istio-ingressgateway-647f8dc56f-kqf7g
Namespace:    istio-system
Priority:     0
Node:         rancher-prod1/192.168.1.45
Start Time:   Fri, 19 Mar 2021 21:20:23 +0100
Labels:       app=istio-ingressgateway
              chart=gateways
              heritage=Tiller
              install.operator.istio.io/owning-resource=unknown
              istio.io/rev=default
              operator.istio.io/component=IngressGateways
              pod-template-hash=647f8dc56f
              release=istio
              service.istio.io/canonical-name=istio-ingressgateway
              service.istio.io/canonical-revision=latest
Should also add that I'm using this ingress gateway to access applications via the exposed node port so I know it works.
2021/03/27 20:25:43 [DEBUG] [CORE] NodePoller (0xc0001d45a0) ready to poll, last wait: 30s
2021/03/27 20:25:43 [DEBUG] [CORE] NodePoller (0xc0001d45a0) notifying listener: {l:0xc0000da300 s:0xc0000da360}
2021/03/27 20:25:43 [DEBUG] [CORE] NodePoller (0xc0001d45a0) listener callback - num items: 3 err: <nil>
2021/03/27 20:25:50 [DEBUG] Found endpoints for backend istio-system/istio-ingressgateway: []
Looking at the code for the controller I interpret it from the return type declaration that the NodePoller returned 3 nodes and 0 errors:
type pollData struct {
	nl  []v1.Node
	err error
Controller version: f5networks/k8s-bigip-ctlr:2.3.0
F5 version: BIG-IP 16.0.1.1 Build 0.0.6 Point Release 1
AS3 version: 3.26.0
Any ideas?
Kind regards,
Patrik
  • Update. After deleting everything and re-deploying the members were populated as expected. The question was edited above but for the record the config above had these two conflicting parameters before:
            - --pool-member-type=cluster
    I added the cluster option when troubleshooting something else earlier and forgot to remove it. Newbie mistake!
  •   caught conflicting controller start args. Removed - --pool-member-type=cluster. Fixed it, but still the same issue though.
    Thank you Stan!
  • Wrote a guide for the whole process of running it:
    https://loadbalancing.se/2021/03/28/installing-troubleshooting-and-running-bigip-ingress-controller/
