Dave_22402's avatar
Dave_22402
Apr 19, 2010
Irule switch - comment
How does one put comments into a Irule. This is on V10.
Here is an example of what I want to do - but the iRule Editor says the syntax is wrong:
log local0. "[IP::client_addr]i IP recieved"
switch [IP::client_addr] {
"123.123.123.123" {
comment on where ip is
switch -glob [string tolower [HTTP::uri]] {
"/URL/*" { pool TEST_POOL}
"*" { pool PROD_POOL}
default {
"/URL/*" { HTTP::respond 301 Location }
  • hoolio's avatar
    hoolio
    Hi Dave,
    That rule looks valid to me and the iRule editor on a 10.0.1 unit. What is the exact error you're seeing?
    See this post for details on comments in the switch command:
    http://devcentral.f5.com/Default.aspx?tabid=53&aft=1172116
    and the TCL page for switch:
    http://www.tcl.tk/man/tcl8.4/TclCmd/switch.htm
    Edit: On a side note, it would be more efficient to use IP::addr to check the IP address:
    http://devcentral.f5.com/wiki/default.aspx/iRules/ip__addr
    Aaron
  • Aaron
    Tired to go to http://devcentral.f5.com/Default.as...ft=1172116 and get a mesage "We're Sorry - Your request was not completed as expected "
    Also, with the comments in the iRule Editor - when I try to save it - I get red dots next to each comment line and it does not save the record.
    I have tired a couple of spots in the rule - and inside the switch - it does not work.
    I beielve I have tried the IP:addr - and it gave me the wrong IP - I am wanting the IP of the client machine - is IP:addr suppose to do that?
    Thanks for the feed back.
  • hoolio's avatar
    hoolio
    Hi Dave,
    DC shortens URLs now. Can you try removing the spaces from this URL to get to the page?
    http:// devcentral.f5.com/Default.aspx?tabid=53&aft=1172116
    What's the error that the iRule editor shows at the bottom of the code window for the red dots?
    And here is an example using IP::addr to check a single host or network:
       log local0. "[IP::client_addr] IP recieved"
       if {[IP::addr [IP::client_addr] equals 123.123.123.123]}{
            default { pool PROD_POOL}
             "/URL/*" { HTTP::respond 301 Location https://some.location }
    Aaron
