iRule subdirectory to hostname with URI
I am using subdirectories,
I would like to go from:
subdirectory "/catpics" to redirect to "; which is easy, but I want anything following /catpics to go as well.
ex: http(s)://myhost.com/catpics/baddog to go to ";
or http(s)://myhost.com/catpics/baddog/puppies to go to ";
I do not want it to go to "; - that would be easy
How do I eliminate the "catpics" from [HTTP::uri]
Thanks!
- nathe
Cirrocumulus
You could use "string range". please see iRules 101 - 14 - TCL String Commands Part 2 for an explanation.
As catpics is a fixed length then something like
might work.set newuri [string range $uri 8 end]Hope this helps,
N
