Matt_59153's avatar
Matt_59153
Sep 30, 2008
iRule relocating top level folders to https. Need some help
Hey all,
Our F5 iRules have been in place for quite some time. We just started digging into them as we are having some issues with folder redirects to secure that it looks like someone found a workaround for by creating iRules for the folders.
i.e. http://www.blah.com/folder01 has a rule to redirect to http://www.blah.come/folder01/default.aspx
If the rule doesn't exist the link goes from the folder01 to https://www.blah.com/folder01/
Here is a sample of the iRules and I am wondering if there is something simple I am missing.
if { ([HTTP::uri] ends_with "/folder01") and ([HTTP::host] contains "blah.com") } {
HTTP::redirect "http://www.blah.com/folder01/default.aspx"
} elseif { ([HTTP::uri] ends_with "/folder02") and ([HTTP::host] contains "blah.com") } {
HTTP::redirect "http://www.blah.com/folder02/default.aspx"
} elseif { ([HTTP::uri] ends_with "/folder03") and ([HTTP::host] contains "blah.com") } {
HTTP::redirect "http://www.blah.com/folder03/default.aspx"
} elseif { ([HTTP::uri] ends_with "/folder04") and ([HTTP::host] contains "blah.com") } {
HTTP::redirect "http://www.blah.com/folder04/default.aspx"
} elseif { [matchclass [HTTP::host] equals $::BLAH_Hosts] } {
use pool BLAH_WEB
HTTP::redirect "http://www.blah.com/default.aspx"
Thanks for the help.
  • hoolio's avatar
    hoolio
    How about something like this:
          Check if host contains blah.com (case-insensitive)
         if {[string tolower [HTTP::host]] contains "blah.com"}{
             Redirect based on the requested URI (case-insensitive)
            switch -glob [string tolower [HTTP::uri]] {
               "*/folder01" {
                   Exit HTTP_REQUEST in this rule
                  return
               "*/folder02" {
                  return
               "*/folder03" {
                  return
               "*/folder04" {
                  return
               default {
                  return
         } elseif { [matchclass [string tolower [HTTP::host]] equals $::BLAH_Hosts] } {
            pool BLAH_WEB
    If this doesn't work as you need it to, try adding log statements to track which code paths are running.
    Aaron
