Ed_27995's avatar
Ed_27995
Feb 19, 2009
iRule redirection seems to cause problem under heavier load
Hi All,
We're running a redundant pair of BigIP 1500s to load balance a Blackboard Vista cluster. I created an iRule this morning to redirect autosignon failures from our student portal to a more user-friendly error page than the default page provided with the application.
The rule was enabled around 8 this morning and has been running fine up until now. The user load has gone from under 100 to about 400. The iRule text is:
when HTTP_RESPONSE {
HTTP::collect 384
when HTTP_RESPONSE_DATA {
if { [HTTP::payload] contains "Autosignon Error" } {
HTTP::redirect "http://bellevuecollege.edu/distance/bbredirectss.asp" }
The behavior I've noticed and verified is that earlier this morning, with fewer users, Vista ran at normal speeds. At the present time, with the rule enabled, the login page is extremely slow to load, and may time out.
I've had to create the iRule this way due to the application behavior- if a user with a disabled account experiences an autosignon failure, Vista does not return a 404 error, it returns a 200 message along with a sparse autosignon error page.
I've checked the traffic manager performance and do not see anything to indicate that the processing of the iRule is exceeding system resources.
I'd appreciate any suggestions you have for troubleshooting this issue.
Thanks in advance!
Ed
  • James_Quinby_46's avatar
    James_Quinby_46
    Historic F5 Account
    Many of the HTTP collection iRule examples contain a couple of extra lines to prevent server response chunking...I wonder if adding them in here would make a difference (see http://devcentral.f5.com/wiki/default.aspx/iRules/HTTPPayloadCollection.html).
    Another place to gather data is via a logging iRule - I particularly like this one:
    http://devcentral.f5.com/wiki/default.aspx/iRules/In_Depth_Traffic_Analysis_via_iRule.html
    ...because it logs pretty much everything that's going on. It also logs pretty verbosely, so make sure to turn it off when it's not needed.
