nortendo_279044's avatar
nortendo_279044
May 31, 2018
irule redirect specific uri maintenance mode timestamp
Hi everybody,
i want to create an irule to redirect to a specific uri during the maintenance mode from saturday at 8h00 am until sunday at 20h00 pm .
I found this example below but i need to add a redirection to a specific url during the maintenance mode ...
when RULE_INIT { set static::start_date "2018-06-02 20:30" set static::end_date "2011-06-02 21:00" set static::start [clock scan $static::start_date] set static::end [clock scan $static::end_date] } when CLIENT_ACCEPTED { set now [clock seconds] if {$now > $static::start and $now < $static::end}{ HTTP::respond 301 noserver Location "; Connection Close } }
Thank you so much for your support
Kind regards
  • Hi,
    you can try this (simple and functional):
        set START_OFF_TIME [clock scan "01:00 AM"]
        set END_OFF_TIME [clock scan "05:00 AM"]
    if { ( $now > $START_OFF_TIME ) && ( $now < $END_OFF_TIME ) } {
        HTTP::redirect "http://www.xyz.com/maintenancepage/"
        TCP::close
    Reference (Stanislas Piron): https://devcentral.f5.com/questions/irule-based-on-time-50868
    Let me now if you need assistance on IT
    Regards
