JosephT
Jun 13, 2008iRule redirect help
I have an irule that redirects all traffic to https:
rule https.redirect.irule {
HTTP::redirect https://[HTTP::host][HTTP::uri]
This works fine on a VIP listening on port 80 - all traffic is redirected to https.
I tried applying this to a vip listening on port 8004, but it is not working. Is this even possible?
- The_Bhattman
It should as so long as it's http coming into a VIP on tcp port 8004.
Since i wasn't sure what error you recieved, but you could verify by place a debug stastement into the codewhen HTTP_REQUEST { HTTP::redirect "https://[HTTP::host][HTTP::uri]" log local0. "Client [IP::client_addr] requested [HTTP::host][HTTP::uri] } }
when you test the redirect the "Client..." will be logged into the /var/log/ltm file on the LTM.
hope this helps,
CB - hoolio
When testing with the VIP on port 8004, does the client make requests with the port number in the Host header? If so, you could remove it using the Codeshare example:
http://devcentral.f5.com/Wiki/default.aspx/iRules/HTTPToHTTPSRedirect_302.htmlwhen HTTP_REQUEST { Check if Host header value has a length if {[string length [HTTP::host]]}{ Redirect to the requested host and URI (minus the port if specified) HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri] } else { Redirect to VIP's IP address HTTP::redirect https://[IP::local_addr][HTTP::uri] } }
Aaron
