Edouard_Zorrill's avatar
Edouard_Zorrill
Oct 28, 2016
irule redirect and switch -glob: Default sentence question
Guys, I have the following:
    switch -glob [string tolower [HTTP::uri]] {
      "/app1" {
            pool app1_pool
      "/app2" {
            pool app2_pool
      "/app3/" {
            pool app3_pool
      default {
            ACCESS::session remove
Rather than killing the session with "ACCESS::session remove", what I can use there to send 404 to all pages that are default.
Thanks,
  • If you are looking to serve content with 404 status, you can try something like:
    HTTP::respond 303 content [ifile get PAGE_404]
  • Hi,
    you should also use ACL in APM:
    • rule 1 : /app1 : Allow
    • rule 2 : /app2 : Allow
    • rule 3 : /app3 : Allow
    • rule 4 : /app1 : reject
    assign it in ACL assign or Advance ressource assign.
    with ACL, APM will respond with a dedicated reject page.
