irule problem after upgrade from v9 to v11
After upgrading from v9 to v11.2, irule got some problem.
before upgrade
class http_list {
"abc.com abc-r.com abc-r_pool"
"xyz.com xyz-r.com xyz-r_pool"
"123.com 123-r.com 123-r_pool"
set rp_list $::http_list
set host [HTTP::host]
set proxy_host_entry [findclass [string tolower $host] $rp_list]
if { $proxy_host_entry ne "" } {
set rp_host [getfield $proxy_host_entry " " 2]
set rp_pool [getfield $proxy_host_entry " " 3]
HTTP::header replace "Host" $rp_host
pool $rp_pool
After upgrade
ltm data-group internal /Common/http_list {
records {
"abc.com abc-r.com abc-r_pool" { }
"xyz.com xyz-r.com xyz-r_pool" { }
"123.com 123-r.com 123-r_pool" { }
type string
However should I convert the irule to work in v11.2?
- nitass
Employee
can you create pool starting with numeric i.e. 123-r_pool?root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm data-group internal http_list ltm data-group internal http_list { records { "abc.com abc-r.com abc-r_pool" { } "xyz.com xyz-r.com xyz-r_pool" { } } type string } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.19.252:80 ip-protocol tcp mask 255.255.255.255 profiles { http { } tcp { } } rules { myrule } snat automap vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when HTTP_REQUEST { if {[class search -- http_list starts_with [HTTP::host]]} { set rec [class search -name http_list starts_with [HTTP::host]] HTTP::header replace Host [getfield $rec " " 2] pool [getfield $rec " " 3] log local0. "[HTTP::host] | $rec | [getfield $rec " " 2] | [getfield $rec " " 3]" } } } [root@ve11a:Active:Changes Pending] config tail -f /var/log/ltm Oct 10 15:22:14 tmm info tmm[8764]: Rule /Common/myrule : abc.com | abc.com abc-r.com abc-r_pool | abc-r.com | abc-r_pool Oct 10 15:22:16 tmm info tmm[8764]: Rule /Common/myrule : xyz.com | xyz.com xyz-r.com xyz-r_pool | xyz-r.com | xyz-r_pool - Daniel_55334
Altostratus
Thanks for your reply nitass. I will try that.
Those are just dummy names :)
