cymru81's avatar
cymru81
Aug 12, 2019
irule pool member help
we have a VIP that currently uses this irule:
# Notify the backend servers that this traffic was SSL offloaded by the F5.
 HTTP::header insert "X-Forwarded-Proto" "https";
 HTTP::header remove "X-Forwarded-For"
HTTP::header insert "X-Forwarded-For" [IP::client_addr]
this works as expected.
what we have is a pool though that has two members (2x IIS web servers), these aren't identical and not every site exists on both. Some of them do however and we would like to balance between the two. can we modify the irule in someway so we have granular control over which IP a request hits in a pool.
  • Hi Cymru81,
    You can create a pool for each site then select which to direct traffic to based on the hostname. If the site is on both IIS servers include them both as members, if not just have 1 as a member.
    ltm rule poolselect {
    		set httphost [string tolower [HTTP::host]]
            switch -glob $httphost {
                "site1.com" {
                    pool site1
                "site2.com" {
                    pool site2
                "site3.com" {
                    pool site3
                default {
                    HTTP::respond 404 noserver
                    TCP::close
                    event disable all
