viziony's avatar
viziony
Icon for Cirrus rankCirrus
Feb 03, 2022
iRule Path Routing to pool review.
Hello I have a few designated paths in which I would like to direct to a specific pool otherwise to a default pool. Here is the script that I have came up with using a combination of others I have found on the site. Can you help me confirm this is correct and will work? This is also for HTTPS, so do I need to change "when HTTP_REQUEST" to "when HTTPS_REQUEST"?
if { [string tolower [HTTP::uri]] equals "/a.php" or [string tolower [HTTP::uri]] starts_with "/b.php"} or [string tolower [HTTP::uri]] starts_with "/c/*"} { pool /Common/pool-A_pool } else { pool Common/pool-B_apool }
Thanks for your time.
  • Hi viziony
    I think you could use a switch statement rather than a lot of or conditions. This iRule should work for you.
    Instead of starts_with, I use a wildcard *.  You could also use HTTP::path instead of HTTP::uri.
        switch -glob -- [string tolower [HTTP::uri]] {
            "/a.php*" -
            "/b.php*" -
            "/c.php*" {
                pool my_pool_ABC
            default {
                pool my_pool_XYZ
    Let me know if this one works for you, or it needs adjustments.
    KR
    Daniel
    • viziony's avatar
      viziony
      Thank you Dan for the quick reply! Will update this thread once I test it out.
