Seckin_149390
Feb 10, 2015Irule or Monitor if the application returns with specific string or http response code
Hi All,
Is there any irule or monitor to disable pool member, if the application returns back to the client with specific string or http response code.
string could be " unable to connect with the specified application "
or http response code 404.
Kind Regards.
- iaine
Nacreous
Yep, this sounds like a normal monitor to me. Create your send string correctly - see https://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.html for details - and then enter your string or your HTTP response code in the Receive String section.
