Tom_89796
Jan 12, 2013irule not appending IP
Have the following irule for appending IP address to uri on incoming requests. login and login2 append IP address as expected, ACCGateway in uri is not appending IP address as expected.
switch -glob [string tolower [HTTP::uri]] {
"*login.aspx" -
"*login2.aspx" -
"*ACCGateway.aspx" {
HTTP::uri "[HTTP::uri]?IPAddress=[getfield [IP::client_addr] % 1]"
"*login.aspx\?*" -
"*login2.aspx\?*" -
"*ACCGateway\?*" {
HTTP::uri "[HTTP::uri]&IPAddress=[getfield [IP::client_addr] % 1]"
- hoolio
Make sure to put your switch cases in lowercase as you're setting the URI to lowercase for the switch comparison.
Aaron - Tom_89796
OK, so changing it to the below, but it is still not appending the IP address as expected. The get request conatins this directly - /ACC/ACCGateway.aspx?
I tried adding .aspx to the second entry of accgateway as well with no luck so far. I believe that .aspx should be there?
"*login.aspx" -
"*login2.aspx" -
"*accgateway.aspx" {
"*login.aspx\?*" -
"*login2.aspx\?*" -
"*accgateway.aspx\?*" {
} - Tom_89796
actaully looks like it worked with the change to lower case in the compare. Just didn't wait long enough, must have been cached in my browser
