Rupa_34586's avatar
Rupa_34586
Dec 30, 2009
irule is taking wrong cookie
I am using the below irule for cookie based routing.
The irule is not taking the cookie value properly.I am observing cookies on my browser using HTTP Watch pro.
I see JTAP=POD25 in httpwatch pro and in Irule logs i see JTAP=POD2. I am not sure from where the irule is taking the value POD2. Could somebody please tell wheres wrong
if { [HTTP::cookie "JTAP"] ne "" } {
log local0. " Web tier: *** Found JTAP Cookie: [HTTP::cookie JTAP]"
set JTAP [string tolower [getfield [HTTP::cookie "JTAP"] "^" 3]]
pool p_$JTAP
log local0. "Web tier: *** Request went to $JTAP"
else {
pool p_default
Thanks for your help and have a Happy New Year
  • Hi Rupa,
    Looking at your irule it appears that there are several items in JTAP? Something like "JTAP=value^value2^value3" and you are trying to extra the 3rd field? Just need to understand why you needed the getfield
    Bhattman
  • Hi Bhattman,
    Sorry my bad,
    My cookie JTAP looks like pay^app^pod25. i am retriving the 3rd value from that.Because i named the pool with the 3rd value.
    if you see the first log statement in my irule
    I am logging the JTAP value. I am getting pay^app^pod2 in the logs.But in HTTP watch pro i see JTAP=pay^app^pod25
    what could be the problem?
    Regards,
    Rupa
  • hoolio's avatar
    hoolio
    Hi Rupa,
    The iRule looks straightforward enough. Can you post a sample from the ltm log for a failure?
    Here is a quick test showing the parsing working correctly:
     when RULE_INIT {
        set cookie "abc^def^ghi"
        log local0. " \$cookie: $cookie; \[getfield $cookie \"^\" 3\]: [getfield $cookie "^" 3]"
    And the ltm log output:
    Rule : $cookie: abc^def^ghi; [getfield abc^def^ghi "^" 3]: ghi
    Thanks,
    Aaron
  • hoolio's avatar
    hoolio
    Hi Rupa,
    I was asking if you could post the log output from these two log lines:
    log local0. "Web tier: *** Found JTAP Cookie: [HTTP::cookie JTAP]"
    Also, can you clarify which host you captured the tcpdump. If it was on LTM, was it on the client or server VLAN?
    Thanks,
    Aaron
  • thanks for your reply,
    there is no issue with F5.My webserver is truncating the cookie.
  • hoolio's avatar
    hoolio
    Glad you figured out the problem. Thanks for clarifying it.
    Aaron
