Jason_19901
Apr 05, 2011iRule Help
I am trying to create an iRule to look at the URI and then based on IP address, either allow or deny. Any help would be great!
- Joel_Moses
Is this something like what you're looking to do?
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/52/aft/1178546/showtab/groupforums/Default.aspx - Jason_19901
that link takes me to my post. is that the correct link? - Joel_Moses
Sorry 'bout that. Teaches me to watch what window I'm in when cutting and pasting. Try this one:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/1178517/showtab/groupforums/Default.aspx
The final iRule described here seems close. If this isn't it, let me know. - Jason_19901
so that rule will be able to say...if coming from Remote IP, do not allow and if the IP is NOT REMOTE, allow...correct? what is the DEBUG for? what is the HTTP:PATH used for? sorry for the questions.....new to iRules - Michael_Yates
Yes, the example that Joel points you to is pretty close to what I understand that you need.
It does implement Data Groups to allow for multiple IP Addresses, etc.
Here is a static example. Perhaps you can combine pieces of the two to get exactly what you are needing.when HTTP_REQUEST { if { [[string tolower [HTTP::uri]] starts_with "/website/login.aspx" ] and [IP::addr [IP::client_addr] equals "192.168.1.10"] } { pool matching.pool.name } else { pool nonmatching.pool.name } }
