Sams_88783's avatar
Sams_88783
Dec 01, 2010
Irule Help
We have a site hosted in our webspere server which requires a http redirect.so i have created a irule with
HTTP::redirect "http://[HTTP::host][HTTP::uri]"
This left the WebSphere port in the redirect, how to remove the port ?
Please help with this.
  • hoolio's avatar
    hoolio
    Hi Sams,
    Here are a couple of Codeshare examples which should be relevant:
    http://devcentral.f5.com/wiki/default.aspx/iRules/HTTPToHTTPSRedirect_301.html
    http://devcentral.f5.com/wiki/default.aspx/iRules/RewriteHTTPRedirectPort.html
    Aaron
  • Aaron correct me if i am worng so the irule will be as below correct ? my concern is to remove webspere port because code can add the WebSphere port at any time.
    when HTTP_RESPONSE {
    if { [HTTP::header is_redirect]} {
    HTTP::header replace Location [string map ":[TCP::remote_port]/ /" [HTTP::header value Location]]
  • hoolio's avatar
    hoolio
    If I understand your scenario correctly, that's close. You just need to strip out the port on requests:
        Remove the port from the host header if present and send a redirect to the same URI
       HTTP::redirect "http://[getfield [HTTP::host] : 1][HTTP::uri]"
        Check if response is a redirect baseed on status code
           Update the location header by removing the pool member's port
          HTTP::header replace Location [string map ":[TCP::server_port]/ /" [HTTP::header value Location]]
    Aaron
