smalte_85868's avatar
smalte_85868
Mar 06, 2009
IRule help
I have JDedwards installed on 2 servers under Oracle application server.
I have created a virtual server that point to pool of IP addresses pointing to these 2 servers.
My virtual address is http://erpdev.abc.com
annd my 2 servers jde url is http://server1.abc.com/jde/E1Menu.maf and http://server2.abc.com/jde/E1Menu.maf.
First I want to make sure that the user load is balanced between these 2 servers and also when a user logs into http://erpdev.abc.com it should reslove to one of these servers but keep the server name hidden for eg it should navigate through jde as http://erpdev.abc.com/jde/E1Menu.maf, so its trasparent to the user what jde webserver he is connected to.
Any help in genrating a irule to accomplish this would be highly appreciated.
  • When you tested this, without an irule, did you see the URL change from http://erpdev.abc.com to http://serverX.abc.com...?
    CB
  • Can you post your vip and pool configuration and the irule that you are currently using?
    It may help is drive you to a solution you are looking for.
    Thanks,
    Chetan
  • VIP
    erpdev.ddr.com
    Address : 192.168.7.224 Port 80
    Default Pool: erpdev
    Pool members :
    1. 192.168.7.236:80 points to bwjasp5.ddrc.com
    2. 192.168.7.236:80 points to bwjasp5.ddrc.com
    3. 192.168.7.236:80 points to bwerpwebd2.ddrc.com
    4. 192.168.7.236:80 points to bwerpwebd2.ddrc.com
    Irule: (Manual LB , kinda forcing it to work)
    BEGIN
    when RULE_INIT {
    set ::lb_counter 1
    log local0. "Rule Starting lb_counter is $::lb_counter"
    log local0. "HTTP Request counter is $::lb_counter"
    if { $::lb_counter == 1 } {
    log "Logging to server1"
    HTTP::redirect http://bwjasp5.ddrc.ads/jde/owhtml
    HTTP::header replace Location [string map {bwjasp5.ddrc.ads erpdev.ddr.com} [HTTP::header Location]]
    set ::lb_counter 2
    return
    } elseif { $::lb_counter == 2 } {
    log local0. "Logging to server2"
    HTTP::redirect http://bwerpwebd2.ddrc.ads/jde/owhtml
    HTTP::header replace Location [string map {bwerpwebd2.ddrc.ads erpdev.ddr.com} [HTTP::header Location]]
    set ::lb_counter 1
    END
  • Sorry send some wrong info before
    Pool Members
    1. 192.168.7.236:80 points to bwjasp5.ddrc.ads
    2. 192.168.7.237:80 points to bwjasp5.ddrc.ads
    3. 192.168.7.238:80 points to bwerpwebd2.ddrc.ads
    4. 192.168.7.239:80 points to bwerpwebd2.ddrc.ads
