ryuusei_80455's avatar
ryuusei_80455
15 years ago
iRule for URL base tcp connection limit
Hi I'm writing a URL base tcp connection limit rule.
For capacity of back-end legacy system,
Need to limit the http request at same time.
Any comments or suggestions would be appriciated.
when RULE_INIT {
The maximum number of TCP connections to the virtual server
set ::max_connections 10
Clear the array of clients
array set ::active_clients { }
Set an HTML response to sent to clients who make a request while the VIP is over the max connection
set ::html_content "over limit"
log local0. "\$::active_clients: [array get ::active_clients] (size: [array size ::active_clients])"
if { [HTTP::path] ends_with "LIMIT URL" } {
Check if client is already over the maximum
if { [array size ::active_clients] > $::max_connections } {
log local0. "Limited connection from [IP::client_addr]:[TCP::client_port] (size: [array size ::active_clients])"
Send a response
HTTP::respond 200 content $::html_content
Close the connection
TCP::close
set ::active_clients([IP::client_addr]:[TCP::client_port]) 1
if { [info exists ::active_clients([IP::client_addr]:[TCP::client_port])]} {
Clear the array element
unset ::active_clients([IP::client_addr]:[TCP::client_port])
when HTTP_RESPONSE {
Check if the client is in the array
when CLIENT_CLOSED {
