Thomas_53413's avatar
Thomas_53413
Jun 02, 2017
iRule for URI 'Percent encoding' doesn't work
Hi Guys,
We use different iRules in the same VS with the same event triggers. This should be possible in SW-Vers. 12.1.2.
The functions are different, of course.
So the 1st iRule is generally installed in many VSn and the 2nd iRule is specifically only for one VS.
the problem:
in an URI of an http-request are represented European ASCII special characters with "Percent-encoding" (e.g. '%C3%9F' for character 'ß' or '%C3%BC' for character 'ü').
For the correct translation of ASCII special characters in the URI we use the 2nd iRule. We want to use the 'URI :: decode' function for correction.
We have the following problem:
It seems as if the rule works fine and the function is executed (I see the processing run in the log-file) but the request to the poolmember transfers the original uri ( I see this in the tcpdump and in the server-log-file).
What could be the issue? What's wrong on the setting?
Any ideas everyone?
  • The iRule:
    log local0. "Original-URI: [HTTP::uri]"
    log local0. "Decode-URI: [URI::decode [HTTP::uri]]"
    HTTP::uri [URI::decode [HTTP::uri]]
    log local0. "Ausgabe-URI: [HTTP::uri]"
    if { ( [HTTP::header Authorization] starts_with "Digest ," ) } {
    HTTP::header replace "Authorization" "Digest [string range [HTTP::header Authorization] 8 end]"
    if { ( [HTTP::header Content-Type] equals "application/x-www-form-urlencoded" ) } {
    HTTP::header replace "Content-Type" "text/xml"
    switch -glob [string tolower [HTTP::path]] {
    "/monitor/" {
    return
    "/manager/" {
    reject
    default {
    return
    when HTTP_REQUEST_SEND {
    clientside {
    HTTP::header replace Host "[IP::server_addr]:[TCP::server_port]"
  • Logging the irule to the ltm-logfile:
  • Jun 2 08:17:06 inwclb26t2 info tmm4[22109]: Rule /Common/rule_url_rewrite_tui2-mbbservices04.audi-connect.de : Original-URI: /mbb/poi/v2/?key=K%C3%BCnstler&lan=de_DE&lat=48.7863736900761&lon=11.394827225496007&num=10&index=0&radius=500&session=8871223&hu_region=eu_rdw&implicitLocation=n
  • Jun 2 08:17:06 inwclb26t2 info tmm4[22109]: Rule /Common/rule_url_rewrite_tui2-mbbservices04.audi-connect.de : Decode-URI: /mbb/poi/v2/?key=Künstler&lan=de_DE&lat=48.7863736900761&lon=11.394827225496007&num=10&index=0&radius=500&session=8871223&hu_region=eu_rdw&implicitLocation=n
  • Jun 2 08:17:06 inwclb26t2 info tmm4[22109]: Rule /Common/rule_url_rewrite_tui2-mbbservices04.audi-connect.de : Ausgabe-URI: /mbb/poi/v2/?key=Künstler&lan=de_DE&lat=48.7863736900761&lon=11.394827225496007&num=10&index=0&radius=500&session=8871223&hu_region=eu_rdw&implicitLocation=n
  • Tcpdump towards poolmember:
GET /mbb/poi/v2/?key=K..nstler&lan=de_DE&lat=48.7863736900761&lon=11.394827225496007&num=10&index=0&radius=500&session=8871223&hu_region=eu_rdw&implicitLocation=n HTTP/1.1
User-Agent: JavaJ2ME Foundation Specification v1.1
Host: 10.242.80.61:18581
Connection: keep-alive
Authorization: Digest qop=auth, uri="/mbb/poi/v2/?key=K%C3%BCnstler&lan=de_DE&lat=48.7863736900761&lon=11.394827225496007&num=10&index=0&radius=500&session=8871223&hu_region=eu_rdw&implicitLocation=n", response="44ddd10666390112fa3a26f999e617ce", nc=00000005, username=" xxx ", opaque=" xxx ", realm="AudiT1Realm", nonce=" xxx ", algorithm="MD5", cnonce=" xxx "
Accept-Encoding: gzip
Cookie: LBCOOKIE=1028715018.38216.0000
Forwarded-Mandant: INET
X-Forwarded-Host: xxx
X-Forwarded-For: xxx
X-Forwarded-Proto: https
Thx in advance - Thomas
  • Hi,
    Why are you trying to "correct" the URL? ß is not a valid character in URI, so it must be encoded.
    if you insert such character, the request may be wrong...
    only US-ASCII (according to RFC 3986, not changed in RFC 6874 and 7320) are supported and non US-ASCII characters must be encoded.
