vvskaladhar_488's avatar
vvskaladhar_488
Jun 22, 2018
Solved
Irule for restricting selected ips for NOT USING TLSV1 and 1.1
Hello All, I have requirement of use an iRules in F5 to enable TLS V1.0 and 1.1 only for Selected IP addresses or IP ranges. and enable only TLS 1.2 for all remaining . I have tried the irule below by creating data group list with Name"TLSV1.0_1.1_Disable" and 2 SSL profiles with tls disabled and enabled .but i see the error below, can some one please suggest me if there is any irule or procedure to follow for this requirement?
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] eq $TLSV1.0_1.1_Disable ]} {
SSL::profile SSLprofile1---------------> TLSv0and1 enabled
SSL::profile SSLprofile2_Disable------------->TLSv0and1 enabled.
Error i am seeing is below. where kaladhar_test is name of the irule
01070151:3: Rule [/Common/Kaladhar_test] error: /Common/Kaladhar_test:2: error: [Invalid IP address][TLSV1.0_1.1_Disable]
  • matchclass ...
    Note: matchclass has been deprecated in v10 in favor of the new commands. The class command offers better functionality and performance than matchclass.
    Inserting the appropriate class command into this iRule would look something like this:
        if { [class match [IP::client_addr] equals TLSV1.0_1.1_Enable ]} {
            SSL::profile example_profile_enable_weak_TLS
            SSL::profile example_profile_disable_weak_TLS
    • vvskaladhar_488's avatar
      vvskaladhar_488
      Thanks you so much for the help on this. i am able to add the irule as below and waiting for the confirmation form the client to say ready for testing. below is the irule by taging to the vip kaladhar.abc.com.
      if { [matchclass [IP::client_addr] contains TLSV1.0_1.1_Disable ]} {
      SSL::profile kaladhar.abc.com_TLS_Disable
      vvskaladhar_488
  • kcrawford4597_1's avatar
    kcrawford4597_1
    Historic F5 Account
    matchclass ...
