MustphaBassim's avatar
Mar 09, 2024
iRule for Close session on failover
Hello Dears
I am trying to make iRule to close the connection with backend server when failover take place from F5-1 to F5-2 that would inform the backend to close anyconnection and then the F5-2 would re-connect with backend server again.
Bests
  • MustphaBassim I do not believe this is possible. What issue are you attempting to resolve for that would necessitate manually closing down connections that use to be formed to F5-1?
    • MustphaBassim's avatar
      MustphaBassim
      Icon for Cirrus rankCirrus
      Hello Dear
      the issue is the backend server keep the session estibshled and not closing the connection when change from node 1 to node 2 of F5 device
      • Paulius's avatar
        Paulius
        Icon for MVP rankMVP
        MustphaBassim What type of connections are these? Can you provide the configuration of the virtual server and pool in question?
