Sonny_J_Bonds_1's avatar
Sonny_J_Bonds_1
Mar 31, 2015
Solved
iRule Exception Help
I have this rule setup on Virtual serverA to allow communication to happen only on the port listed below. I now want to set it so it doesn't run through the rule below when this incoming IP (192.x.x.20) hits it. The IP 192.x.x.20 is a server I want to be the only exception to this rule (no filtration) when it hits serverA, how do I make this happen?
Thank you.
when CLIENT_ACCEPTED {
 Check if requested port equals the port numbers below
if { not (
    [TCP::local_port] == 25 or
    [TCP::local_port] == 53 or
    [UDP::local_port] == 53 or
    [UDP::local_port] == 67 or
    [TCP::local_port] == 88 or
    [UDP::local_port] == 88 or
    [UDP::local_port] == 123 or
    [TCP::local_port] == 135 or
    [UDP::local_port] == 137 or
    [UDP::local_port] == 138 or
    [TCP::local_port] == 139 or
    [TCP::local_port] == 389 or
    [UDP::local_port] == 389 or
    [TCP::local_port] == 443 or
    [TCP::local_port] == 445 or
    [UDP::local_port] == 445 or
    [TCP::local_port] == 464 or
    [UDP::local_port] == 464 or
    [TCP::local_port] == 636 or
            [TCP::local_port] == 1433 or
    [UDP::local_port] == 2535 or
    [TCP::local_port] == 3268 or
    [TCP::local_port] == 3269 or
    [TCP::local_port] == 3389 or
    [TCP::local_port] == 5722 or
    [TCP::local_port] == 8014 or
    [TCP::local_port] == 9389 or
            [TCP::local_port] == 49155
    Drop request
   drop
  • I would try with:
    if { not [IP::addr [IP::client_addr] equals "192.x.x.20"] }
       if { not (
    Drop request drop } }
  • I would try with:
       if { not (
  • Works like a charm DevBabu, thank you - I really appreciate that. I came very close to having something similar, was missing a closing bracket.
    Thanks again.
