Ranvir_Floura_7's avatar
Ranvir_Floura_7
Jan 02, 2008
iRule and trailing slash issue
Folks,
Got a issue that is bugging me. Here is the iRule that I am working off and it works for the most part, but i have to put the trailing "/" for it to work. I need to have it working without the slash at the end.
if { [string tolower [HTTP::uri]] starts_with "/dev3" } {
HTTP::uri [string range [HTTP::uri] 5 end]
pool dev3
The dev3 entry is mostly working as long as you remember to include a trailing "/" on the URL -- so https://www.aaa.bbb.com/dev3/ works where https://www.aaa.bbb.com/dev3 does not, it gives a message about a bad request.
Any ideas?
  • hoolio's avatar
    hoolio
    With that rule, if the URI was just /dev3, the URI sent to the web app would be null. That's not valid in HTTP. You could use this to check the URI:
           Set the pool to dev3 for all requests starting with /dev3
          pool dev3
           Remove /dev3 from the URI
          set uri [string range [HTTP::uri] 5 end]
           Check if updated URI has a length
          if {$uri}{
              Updated URI has a length, so set the request to the updated URI
             HTTP::uri $uri
              Updated URI was empty, so set the URI to /
             HTTP::uri /
    Aaron
