cbwagner_13922
Apr 20, 2012iRule and Host Headers
So with apache, you can list *.mydomain.com and apache will answer for all requests comming in that match the wildcard + mydomain.com. No such luck with IIS7. Is there anyway through iRules to match a wildcard domain, but keep the wildcard domain name in the URL (so the client doesn't know the difference) but pass the correct host header to the webservers.
so request for bloging.mydomain.com comes in.
The F5 passes www.mydomain.com to the webserver,
the webserver sees www.mydomain.com in its host header,
it passes back the next page, link, etc.
the F5 passes back the page, but displays the URL bloging.mydomain.com to the client...
possible? impossible?
- nitass
Employee
e.g.[root@ve1023:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve1023:Active] config b pool foo list pool foo { members 200.200.200.101:80 {} } [root@ve1023:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if { [HTTP::host] equals "bloging.mydomain.com" } { HTTP::header replace Host "www.mydomain.com" } } } [root@ve1023:Active] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.19.251(54281) <-> 172.28.19.79(80) 1334971345.3088 (0.0010) C>S --------------------------------------------------------------- HEAD /something HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: bloging.mydomain.com Accept: */* --------------------------------------------------------------- New TCP connection 2: 200.200.200.10(54281) <-> 200.200.200.101(80) 1334971345.3120 (0.0031) C>S --------------------------------------------------------------- HEAD /something HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: www.mydomain.com Accept: */* ---------------------------------------------------------------
