Gerald_Meese's avatar
Jan 11, 2018
iRule - Combine HTTP::redirect and Basic Auth in HTTP header
Hello,
I'm trying to adapt an iRule that would combine the redirect to a specific URI on the backend server, while sending Basic Authentication in an HTTP header to that backend server :
   set logindata [b64encode "username:password"]
   HTTP::redirect "/internalURI"
   HTTP::header replace Authorization "Basic $logindata"
Both commands work well separately, and I believe I understand where the problem is (the redirect sends a new path to the client while the HTTP header is added into the traffic to the backend) but I can't figure out how to get this to work.
Thanks in advance for your help !
Kind regards,
Gerald
  • You can try this code:
        if {[HTTP::uri] starts_with  "/internalURI"} {
