janholtz's avatar
janholtz
Apr 22, 2019
Internal datagroup REST / curl problem
What is the correct format for a file to populate an internal data group with a curl command?
I tried:
curl -vk -u xxxxx:xxxxx -H 'Content-Type:application/json' -X POST -d text.json
And in text.json I have the content of: curl -vk -u xxxxx:xxxxx -H "Content-Type:application/json" -X GET -o text.json
Surely the format of the records from a GET are correct for the format of records for a POST??? (I tried a PUT too, no joy).
Jan
  • Hi Jan,
    the raw GET output can't be used to create or update a given data-group.
    To create a new data-group:
    curl -k -u "admin:admin" -H "Content-Type: application/json" -X  POST -d '{"name":"DG_SOMEVALUES","type":"string","records":[{"name":"123","data":"abc"}]}' https://172.22.17.1/mgmt/tm/ltm/data-group/internal/
    To update the records of an existing data-group:
    curl -k -u "admin:admin" -H "Content-Type: application/json" -X  PATCH -d '{"records":[{"name":"1234","data":"xyz"}]}' https://172.22.17.1/mgmt/tm/ltm/data-group/internal/~Common~DG_SOMEVALUES
    Cheers, Kai
