Sekhar's avatar
Sekhar
Feb 19, 2015
intermittent distorted display
Hi I am having a website when accessed through F5, the format of the page changes intermittently. I tried changing the profile to tcp on both client and server end but the result is the same. Please help me in fixing this issue . Below are my settings for that VIP.
ip-protocol tcp
mask 255.255.255.255
pool PL_test_App_https
profiles {
    PR_wildcard_clientssl {
        context clientside
    http_security { }
    serverssl-insecure-compatible {
        context serverside
    tcp-lan-optimized {
        context serverside
    tcp-wan-optimized {
        context clientside
source 0.0.0.0/0 source-address-translation { type automap } vlans { external internal } vlans-enabled vs-index 827 }
Thanks, Sekhar
  • Hi Sekhar, it looks okay. What are you doing with the http profile? Would you please dump the following: tmsh list ltm profile http http_security Thanks, Stephan PS: In case your page looks different, perhaps it is missing css files? Issue happens as well, if you have only a single server poolmember enabled?
  • Sekhar's avatar
    Sekhar
    here is my http profile: ltm profile http http_security { app-service none defaults-from PR_HTTP_XFF_Enabled_http security enabled } Thanks, Chandra
  • Sekhar's avatar
    Sekhar
    I have even changed the http profile to default http and tested the app. But it showed no difference.
  • without seeing a capture, this seems like a css/js file is not being sent with a secure link.
  • Sekhar's avatar
    Sekhar
    Hi Stephan,
    After enabling persistence for this profile and changing my protocol profile to tcp for both client and server solved the issue. But I am not sure how this still fixed the issue. Any ideas on this?
    Thanks, Sekhar
