frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:- Ne...
mikand_61525
Jan 26, 2012Just guessing now but couldnt part of the problem be that you didnt setup any vlan-configuration between your F5's (currently only state-sync)?
I mean your Internal (4093) must exists on the "Fibre" bonding aswell. Otherwise you end up with assymetric situations where the lan-switch2 sends data to ltm-b when ltm-b is passive which gives that it receives the packet but doesnt know what to do with it which ends up with a drop.
If you enable the 4093-vlan on the "Fibre" between ltm-a and ltm-b then the passive unit will send the packet to the active unit for processing (if im not mistaken).
Sidenote: Why no bonding for the F5 -> WAN-switches?
