skuchma_87556's avatar
skuchma_87556
Sep 27, 2012
Integration between GTM VE and LTM VE
Hello Colleagues,
We have two LTM VE installed as HA pair and want to test GTM functionality. So we install two new GTM VE as sync group. Bigip_add between GTM was passed successfully and both GTM have certificates of each other. Now I try to add LTM to GTM. So I try to run big3d_install and point it to LTM management ip address, but scripts ask me root password from LTM. My LTM VE doesn't have root login (only admin) - root access disapeared after LTM provisioning. All LTM and GTM are version 11.1. How I can use admin username instead?
Best Regard,
Stanislav Kuchma
  • After exchanging certificates btw LTM and GTM, the big3d_install was successfully ran over LTM. But VS auto discovery in GTM doesnt work.
  • VS autodiscovery start working after I've added GTM as server in DataCenter.
    • Eric_Hartwell_1's avatar
      Eric_Hartwell_1
      this is still necessary in 11.4.1. This is not in the documentation and almost doesnt make sense.
