tbw_90635's avatar
tbw_90635
Jul 21, 2009
Integer Property of Monitor Templates
A monitor template configured with interval=5 and timeout=16 was setup on three version of BigIP.
I called_template_integer_property() using the template name and the types: ITYPE_INTERVAL, ITYPE_TIMEOUT, ITYPE_PROBE_NUM_PROBES, ITYPE_PROBE_NUM_SUCCESSES, and ITYPE_PROBE_TIMEOUT
On a BigIP 9.3:
ITYPE_INTERVAL: 5
ITYPE_TIMEOUT: 16
ITYPE_PROBE_NUM_PROBES: null
ITYPE_PROBE_NUM_SUCCESSES: null
ITYPE_PROBE_TIMEOUT: null
Result: works as expected with correct results
On a BigIP 9.4 (Common partition):
ITYPE_INTERVAL: 0
ITYPE_TIMEOUT: 16
ITYPE_PROBE_NUM_PROBES: 1
ITYPE_PROBE_NUM_SUCCESSES: 1
ITYPE_PROBE_TIMEOUT: 5
Result: seems like the interval value moved to the probe timeout.
On a BigIP 10.0.1 (Common partition):
ITYPE_INTERVAL: 5
ITYPE_TIMEOUT: 0
ITYPE_PROBE_NUM_PROBES: 0
ITYPE_PROBE_NUM_SUCCESSES: 0
ITYPE_PROBE_TIMEOUT: 0
Result: only interval has the correct value
(I'm using the iControl assembles jar supplied by Dev Central with java 1.6)
If find these results confusing. The only one that really works is when using a v9.3 Bigip.
  • Can you clarify on whether you were getting or setting these values? I'll look into the code to see what's going on with the different version but I need to be able to reproduce your issue. It's not clear on whether the error is while you are trying to set the values or retrieving them.
    -Joe
  • I'm just attempting to get some of the monitor values using LocalLB.Monitor.get_template_integer_property()
  • I just verified that on 10.0.1 the returned results are correct with the iControl assembly for .NET. Since the java library uses the same passthru logic, the results should be the same.
    PS C:\> $ic.LocalLBMonitor.get_template_integer_property( `
    ("my_http", "my_http", "my_http", "my_http", "my_http"), `
    ("ITYPE_INTERVAL", "ITYPE_TIMEOUT", "ITYPE_PROBE_NUM_PROBES", "ITYPE_PROBE_NUM_SUCCESSES", "ITYPE_PROBE_TIMEOUT") )
    type value
    ITYPE_INTERVAL 5
    ITYPE_TIMEOUT 16
    ITYPE_PROBE_NUM_PROBES 0
    ITYPE_PROBE_NUM_SUCCESSES 0
    ITYPE_PROBE_TIMEOUT 0
    Could you post the code you are using to make the calls?
    -Joe
  • I see the error of my ways :-)
    I'm not using the same monitor name, for each property type.
    Thanks, Joe
    String [] monitorName = { "http", "https", "tcp", "icmp", "udp", "ftp" }; // wrong
    LocalLBMonitorIntPropertyType [] ptype = {
    LocalLBMonitorIntPropertyType.ITYPE_INTERVAL,
    LocalLBMonitorIntPropertyType.ITYPE_TIMEOUT,
    LocalLBMonitorIntPropertyType.ITYPE_PROBE_NUM_PROBES,
    LocalLBMonitorIntPropertyType.ITYPE_PROBE_NUM_SUCCESSES,
    LocalLBMonitorIntPropertyType.ITYPE_PROBE_TIMEOUT
    LocalLBMonitorIntegerValue [] ivalue = m_monitor.get_template_integer_property(monitorName, ptype);
  • Therein lies your issue. The method takes two arrays, the first is for the monitor names, the second is for the property types. This method was designed a bit different that some of the others in our API. For this method, you must pass in a pair of monitor name and type for the n'th index in each array. As you noticed, in your code you were querying the following attributes from the following monitor templates:
     template -> property
     http -> ITYPE_INTERVAL
     https -> ITYPE_TIMEOUT
     tcp -> ITYPE_PROBE_NUM_PROBES
     icmp -> ITYPE_PROBE_NUM_SUCCESSES
     udp -> ITYPE_PROBE_TIMEOUT
     ftp -> ???
    The ftp entry will be ignored since there were only 5 entries in the property type array.
    The correct logic would have been to pass in 5 entries with all 5 monitor template names being the same value for the template you were requesting.
    Let me know if you run into any other issues...
    -Joe
