lossless_186906's avatar
lossless_186906
Oct 26, 2018
Insert X-Frame-Options Header using LTM Policy
I am looking to insert X-Frame-Options header usnig LTM Policy instead of iRules (less resource intensive). Has anyone done it and can confirm if the following would work please or can suggest a better way?
ltm policy policy_HTTP_Security_Headers {
    requires { http }
    rules {
        Insert_X-Frame-Options_Header {
            actions {
                0 {
                    http-header
                    response
                    insert
                    name X-Frame-Options
                    value SAMEORIGIN
            conditions {
                0 {
                    http-header
                    response
                    not
                    values { SAMEORIGIN }
            ordinal 1
    strategy all-match
Would this insert the header if it's missing or only replace it if does not contain the correct value? Thank you in advance.
Regards, Los
  • This policy would insert the X-Frame-Options header in the response if the server's response didn't include an X-Frame-Options header with the value "SAMEORIGIN".
  • Just want to update all that I finally implemented the policy and it works perfectly. Ended up adding X-Frame-Options as well as X-XSS-Protection headers. Below is the code for everyone that is looking to do the same:
    requires { http }
    rules {
        rule_Insert_X-Frame-Options_Header {
            actions {
                0 {
                    http-header
                    response
                    insert
                    value SAMEORIGIN
            conditions {
                0 {
                    http-header
                    response
                    not
            ordinal 2
        rule_Insert_X-XSS-Protection_Header {
            actions {
                0 {
                    http-header
                    response
                    insert
                    name X-XSS-Protection
                    value "1;mode=block"
            conditions {
                0 {
                    http-header
                    response
                    not
                    values { "1;mode=block" "1; mode=block" }
            ordinal 1
    strategy all-match
    Cheers, L
