FishNiX_29746
Oct 22, 2009Insert header for content returned from ramcache?
Is it possible in 9.4.8 to insert a response header into content returned from the cache?
when CACHE_RESPONSE {
HTTP::header insert Via F5-Cache
or something?
- FishNiX_29746
I get these errors:
Oct 22 15:04:18 tmm tmm[1895]: 01220001:3: TCL error: set_xcache_header - Out of bounds (line 1) invoked from within "HTTP::header insert Via F5-Cache"
Oct 22 15:04:19 tmm tmm[1895]: 01220001:3: TCL error: set_xcache_header - Out of bounds (line 1) invoked from within "HTTP::header insert Via F5-Cache"
Oct 22 15:04:19 tmm tmm[1895]: 01220001:3: TCL error: set_xcache_header - Out of bounds (line 1) invoked from within "HTTP::header insert Via F5-Cache" - hoolio
You could have posted the error the first time :D. The wiki page for CACHE_RESPONSE shows HTTP::header should work. But per this old post (Click here), it looks like you should try CACHE::header instead:
CACHE::header insert Via F5-Cache
You might also try opening a case with F5 Support about the TCL error. Either the iRule validation in the GUI/CLI/iControl should prevent you from using HTTP::header in CACHE_RESPONSE, or it should work during runtime.
Aaron
