Incorrect balancing using two pools based on cookies.
sorry colleagues, the description was cutted.
The problem is in incorrect balancing within two server pools. It works fine for 1 pool and goes unpredictabe for another. We have have two rules, 1 - defined pool 2 - check cookie and insert persistant record for server - cookie pair.
It works fine untill we've switch off one of the servers from the second pool. If so - all sessions comes to one server of the pilot pool, instead of balancing over 6 others virtual severs. I've put the existing rule in Preformatted code.
Maybe there are some predefine patterns and best practice for iRules we can use for that configuration ?
WBR, Dmitry.
when HTTP_REQUEST
set need_cookie 0
set pinned_to_pilot 0
set pilot_region 0
set remove_bIPs_cookie 0
set do_not_persist 0
if { [HTTP::cookie exists "bIPs"] }
LB::detach
set cookie_bIPs [HTTP::cookie value "bIPs"]
switch -- $cookie_bIPs
"564844779" {
set pinned_to_pilot 1
"-538018688" {
"-1461105642"{
"836771244"{
"1189555514"{
"-662456167"{
"-1350268913" {
if { [HTTP::cookie exists "MVID_CITY_ID"] }
set cookie_local [HTTP::cookie value "MVID_CITY_ID"]
if { [class match $cookie_local equals ATG_PILOT_COOKIE_GROUP] }
set pilot_region 1
set bIPs_crc_num ""
if {[HTTP::query] contains "o.bIPs"}
set bIPs_crc_num [URI::query [HTTP::uri] "o.bIPs"]
switch -glob [HTTP::host]
"*mvl.ru"
set domain "[www.mvl.ru"](//www.mvl.ru);
if
not ([HTTP::path] starts_with "/assets/")
and not ([HTTP::path] starts_with "/media/")
and not ([HTTP::path] starts_with "/errors/holdingPage.html")
and not ([HTTP::path] starts_with "/sitemap.xml")
and not ([HTTP::path] starts_with "/robots.txt")
and not ([HTTP::path] starts_with "/sitemaps")
and not ([HTTP::path] starts_with "/affiliates_unloads/")
and not ([HTTP::path] starts_with "/favicon.ico")
if { ([HTTP::cookie value "bIPs"] ne "") }
if { not ($pinned_to_pilot) and not ($pilot_region) }
persist uie [HTTP::cookie value "bIPs"]
set need_cookie 0
elseif { ($pinned_to_pilot) and ($pilot_region) }
set need_cookie 0
else
set need_cookie 1
set do_not_persist 1
else
set need_cookie 1
if { ($bIPs_crc_num ne "") }
when LB_SELECTED
if {
`if { ([HTTP::cookie value "bIPs"] ne "") and not ($do_not_persist) }
when PERSIST_DOWN
set need_cookie 1
when HTTP_RESPONSE
set pool_is_dynamic 0
if { ([LB::server pool] == "/Common/atg-ps-prod_tcp80") or ([LB::server pool] == "/Common/atg-pilot-pool")}
set pool_is_dynamic 1
HTTP::cookie insert name "bIPs" value [crc32 [IP::server_addr]] path "/" domain $domain version 1
HTTP::cookie httponly bIPs enable
if { ($need_cookie) and ($pool_is_dynamic) }
catch { persist add uie [crc32 [IP::server_addr]] }
}2 Replies
