John_Stevensen's avatar
John_Stevensen
Oct 30, 2012
Incoming 443 Passthru LTM and use iRule to redirect to pool
Client connections come in SSL 443; needs to pass-thru the LTM with no modification/terminating.
The Clients SSL session needs to terminate directly on the server. The LTM cannot touch the session. Trying to use the irule to look for a string in the URL - if found redirect to pool_2_8089. If string doesnt exist - default to pool_1
pool_2_8089
Member server 192.168.1.101:8089 (is terminating SSL)
pool_1
Member server 192.168.1.101:443 (exact same server just terminating SSL at 443)
I have this iRule
if { ([active_members pool_2_8089] > 0) and ([HTTP::uri] contains "/submitVXUMessage") } {
pool pool_2_8089}
else {pool pool_1}
The vs_dbtest
listening at 443
no ssl client or server profiles
In order to use iRule - I had to select http profile
pool_1 is default
ANY help is much appreciated.
