shadab_8933
Dec 15, 2011Importing SAN certificate using IControl
I need to know if the API - Management::KeyCertificate::certificate_import_from_pem() allows importing SAN certificate. If not, what are my options of importing SAN certficate using IControl.
Thanks.
Shadab.
- George_Watkins_Historic F5 AccountYes, that is the method you would use to import a certificate from PEM format. The method is the equivalent of navigating to Local Traffic > SSL Certificiate List > Import, selecting "certificate" from the "Import Type" drop-down, and pasting the PEM-formatted certificate text. Hope that helps,
George
