Impact for Apache Tomcat Vulnerabilities for Big-IP devices
I am researching a bunch of CVE's to try and ascertain if the BIG-IP LTM or EM is effected and I cannot find SOL articles for a majority of them, thought I would post them here before opening support tickets.
From the F5 Big-IP 3rd party software matrix it looks like all versions of Big-IP devices would need the tomcat patched for the following CVE's:
CVE-2015-5174: Directory traversal vulnerability in RequestUtil.java in Apache Tomcat 6.x before 6.0.45, 7.x before 7.0.65, and 8.x before 8.0.27 allows remote authenticated users to bypass intended SecurityManager restrictions and list a parent directory via a /.. (slash dot dot) in a pathname used by a web application in a getResource, getResourceAsStream, or getResourcePaths call, as demonstrated by the $CATALINA_BASE/webapps directory.
CVE-2015-5345: The Mapper component in Apache Tomcat 6.x before 6.0.45, 7.x before 7.0.67, 8.x before 8.0.30, and 9.x before 9.0.0.M2 processes redirects before considering security constraints and Filters, which allows remote attackers to determine the existence of a directory via a URL that lacks a trailing / (slash) character.
CVE-2015-5346: Session fixation vulnerability in Apache Tomcat 7.x before 7.0.66, 8.x before 8.0.30, and 9.x before 9.0.0.M2, when different session settings are used for deployments of multiple versions of the same web application, might allow remote attackers to hijack web sessions by leveraging use of a requestedSessionSSL field for an unintended request, related to CoyoteAdapter.java and Request.java.
CVE-2015-5351: The (1) Manager and (2) Host Manager applications in Apache Tomcat 7.x before 7.0.68, 8.x before 8.0.31, and 9.x before 9.0.0.M2 establish sessions and send CSRF tokens for arbitrary new requests, which allows remote attackers to bypass a CSRF protection mechanism by using a token.
CVE-2016-0706: Apache Tomcat 6.x before 6.0.45, 7.x before 7.0.68, 8.x before 8.0.31, and 9.x before 9.0.0.M2 does not place org.apache.catalina.manager.StatusManagerServlet on the org/apache/catalina/core/RestrictedServlets.properties list, which allows remote authenticated users to bypass intended SecurityManager restrictions and read arbitrary HTTP requests, and consequently discover session ID values, via a crafted web application.
CVE-2016-0714: The session-persistence implementation in Apache Tomcat 6.x before 6.0.45, 7.x before 7.0.68, 8.x before 8.0.31, and 9.x before 9.0.0.M2 mishandles session attributes, which allows remote authenticated users to bypass intended SecurityManager restrictions and execute arbitrary code in a privileged context via a web application that places a crafted object in a session.
CVE-2016-0763: The setGlobalContext method in org/apache/naming/factory/ResourceLinkFactory.java in Apache Tomcat 7.x before 7.0.68, 8.x before 8.0.31, and 9.x before 9.0.0.M3 does not consider whether ResourceLinkFactory.setGlobalContext callers are authorized, which allows remote authenticated users to bypass intended SecurityManager restrictions and read or write to arbitrary application data, or cause a denial of service (application disruption), via a web application that sets a crafted global context.
And is there is a patch or solution in the pipeline to mitigate or re-mediate? Is there anyone from F5 that can advise about the impact of these CVE's or should we open support tickets for our devices?
Any advice appreciated.
Best, Steve
