sudhirmirajkar_'s avatar
sudhirmirajkar_
May 05, 2016
IMAP,POP3 Health Monitor setup issue
Hi all,
i am fairly new to F5 and trying to setup a health monitor for a node with POP3 and IMAP services.
i am using the IMAP and POP3 template available in F5.
i supplied it with all the information required but it just checks for few mins and then fails.
can someone please guide me on this.
Thanks, Sudhir
  • Try enabling the (advanced options) debug checkbox on the monitor, and then inspect the log file in /var/log/monitors. That should tell you what's going on, and why it was marked down.
    • Kindly try the following command, to see the exact reason for the monitor marking down the pool member.
    • root@(hostname)(cfg-sync Standalone)(Active)(/Common)(tmos.ltm) show node x.x.x.x detail
    • Also, as suggested - use debug and also look at monitor logs to see the exact reason behind failure.
      **var/log/monitors** - Locate the Monitor and its .log file to see the logs.
    • sudhirmirajkar_'s avatar
      sudhirmirajkar_
      i am the imap to work with ssl authentication using username and password
  • Make sure you are IMAP and POP3 are deployed in non-secure fashion in your setup. Secure IMAP and POP3 are best monitored using external monitor.
