IE8/XP compatible cipher suite
Trying to arrive at a SSL cipher suite that'll mitigate the recent vulnerabilities but still allow legacy IE8/XP clients to negotiate. We're currently on v11.6 and our suite is DEFAULT:!RSA:DHE-RSA-DES-CBC3-SHA:!SSLv3, which is blocking older clients.
Major sites are supporting older clients with TLS_RSA_WITH_3DES_EDE_CBC_SHA but am not sure how to modify our string to support this or even if our F5 version still permits it.
- BPRIDE
Dear Josh,
Can you try to following in the SSL client profile for ciphers. NATIVE+HIGH:NATIVE+MEDIUM:!SSLv3:!RC4:!ADH
Regards Balajirajah P B
- joshm_46566
When we try to apply that, we receiving the following error:
0107157c:3: Selected client SSL profiles do not match security policies for Virtual Server XYZ
However, the current string works OK.
- BPRIDE
Are you able to support the legacy XP client or not?
- joshm_46566
The string works for IE8/XP when applied to profiles that are only associated once on a virtual server. We we get the error below when trying to use it on profiles that are part of a virtual server doing SNI.
- BPRIDE
Are you using the default cipher suite in the profile? Try this following command in bash. tmm --clientciphers 'DEFAULT'
- joshm_46566
We get the error when attempting to apply NATIVE+HIGH:NATIVE+MEDIUM:!SSLv3:!RC4:!ADH on an existing profile.
tmm --clientciphers 'DEFAULT' ID SUITE BITS PROT METHOD CIPHER MAC KEYX 0: 159 DHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 EDH/RSA 1: 158 DHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 EDH/RSA 2: 57 DHE-RSA-AES256-SHA 256 TLS1 Native AES SHA EDH/RSA 3: 57 DHE-RSA-AES256-SHA 256 TLS1.1 Native AES SHA EDH/RSA 4: 57 DHE-RSA-AES256-SHA 256 TLS1.2 Native AES SHA EDH/RSA 5: 57 DHE-RSA-AES256-SHA 256 DTLS1 Native AES SHA EDH/RSA 6: 51 DHE-RSA-AES128-SHA 128 TLS1 Native AES SHA EDH/RSA 7: 51 DHE-RSA-AES128-SHA 128 TLS1.1 Native AES SHA EDH/RSA 8: 51 DHE-RSA-AES128-SHA 128 TLS1.2 Native AES SHA EDH/RSA 9: 51 DHE-RSA-AES128-SHA 128 DTLS1 Native AES SHA EDH/RSA 10: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1 Native DES SHA EDH/RSA 11: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1.1 Native DES SHA EDH/RSA 12: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1.2 Native DES SHA EDH/RSA 13: 22 DHE-RSA-DES-CBC3-SHA 192 DTLS1 Native DES SHA EDH/RSA 14: 157 AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 RSA 15: 156 AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 RSA 16: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA 17: 53 AES256-SHA 256 TLS1 Native AES SHA RSA 18: 53 AES256-SHA 256 TLS1.1 Native AES SHA RSA 19: 53 AES256-SHA 256 TLS1.2 Native AES SHA RSA 20: 53 AES256-SHA 256 DTLS1 Native AES SHA RSA 21: 60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA 22: 47 AES128-SHA 128 TLS1 Native AES SHA RSA 23: 47 AES128-SHA 128 TLS1.1 Native AES SHA RSA 24: 47 AES128-SHA 128 TLS1.2 Native AES SHA RSA 25: 47 AES128-SHA 128 DTLS1 Native AES SHA RSA 26: 10 DES-CBC3-SHA 192 TLS1 Native DES SHA RSA 27: 10 DES-CBC3-SHA 192 TLS1.1 Native DES SHA RSA 28: 10 DES-CBC3-SHA 192 TLS1.2 Native DES SHA RSA 29: 10 DES-CBC3-SHA 192 DTLS1 Native DES SHA RSA 30: 49200 ECDHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_RSA 31: 49199 ECDHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_RSA 32: 49192 ECDHE-RSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_RSA 33: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1 Native AES SHA ECDHE_RSA 34: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.1 Native AES SHA ECDHE_RSA 35: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.2 Native AES SHA ECDHE_RSA 36: 49191 ECDHE-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_RSA 37: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1 Native AES SHA ECDHE_RSA 38: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.1 Native AES SHA ECDHE_RSA 39: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.2 Native AES SHA ECDHE_RSA 40: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1 Native DES SHA ECDHE_RSA 41: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1.1 Native DES SHA ECDHE_RSA 42: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1.2 Native DES SHA ECDHE_RSA
