iloveniu_38329's avatar
iloveniu_38329
Dec 21, 2009
iControl.Interfaces.initialize() always return true
hi,everybody
in my application,i used the interface intialize()
bool m_bIsInitialized = m_interfaceF5.initialize(ip, port, username, password);
any string to be given,the return value is always true?
why?
thanks for your reply!
  • which toolkit are you using? The .NET assembly or the Java library? The .NET Assembly by default makes a call to System.SystemInfo.get_version() and if that fails it returns false and stores the exception in the LastException member. Otherwise it returns true.
    For Java, the initialize method will, as you said, always return true if you pass in all the parameters. I guess I should change that to test the interfaces as well. I'll go ahead and update the Java library that I just put out for v10.1 with code to make a test call.
    Thanks for the feedback, I wrote the Java library classes a long time ago and no one has posted this yet. I'll get it coded and reply to this thread when I'm done.
    -Joe
  • I use .net library.
    i use get_time() by myself to get the correct result.
    when ip address, username and password is null,the interface initialize() return true yet.
    this is my code:
    ip.Trim();
    username.Trim();
    password.Trim();
    m_bIsInitialized = m_interfaceF5.initialize(ip, username, password);
    try
    iControl.CommonTimeStamp TimeStamp = m_interfaceF5.SystemSystemInfo.get_time();
    catch (Exception ex)
    m_bIsInitialized = false;
    return m_bIsInitialized;
