Thomas_Weisshaa's avatar
Thomas_Weisshaa
Jul 05, 2012
iControl configsync state issue
I am trying to read the configsync state via iControl to put the results into our system monitoring.
For some reason I don't get valid data. Node 1 and Node 2 differ in the configuration which is correctly indicated via the web gui but not via iControl (Management.DBVariable):
Node 1 (active/passive pair):
Hostname: nw-lb01-dmz-d
Configsync.Autodetect: disable
Configsync.LocalConfigTime: 1341495605
Configsync.PeerConfigTime: 0
Configsync.LocalSyncedTime: 0
Configsync.State: -1 - uninitialized or disabled config state
Node 2 (active/passive pair):
Hostname: nw-lb02-dmz-d
Configsync.LocalConfigTime: 1340281810
Standalone Node in our Testenvironment:
Hostname: lb-dmz.q
Configsync.LocalConfigTime: 1341324396
I am running vCMP LTM 11.1.0 HF4 and using pycontrol2 to query the data.
Do you have an idea what's wrong?
Thank you very much.
Cheers,
Thomas
