Pavlos_Parisis_'s avatar
Pavlos_Parisis_
Nov 16, 2010
ICAP Monitor
Does anyone know if it is possible to have a ICAP monitor on BIG-IP LTM 10.2.0?
I am going to have ICAP servers on a pool and I need to have a monitor for them.
I have looked at the available list but I didn't find any.
Any ideas?
Regards,
Pavlos
  • hoolio's avatar
    hoolio
    Hi Pavlos,
    You could capture a tcpdump of a simple ICAP request and response and handcraft a custom TCP send and receive string for a TCP monitor. Here is a solution detailing the escape sequences you can use in a monitor:
    SOL4186: Entering escape sequences in an ECV health monitor's send and receive strings
    http://support.f5.com/kb/en-us/solutions/public/4000/100/sol4186.html
    Aaron
  • Unfortunately, I can't do that because monitor request must carry the Request Method "OPTIONS" and header "Host" which is different for every pool member.
    Thanks for your reply.
    Regards,
    Pavlos
  • hoolio's avatar
    hoolio
    Hi Pavlos,
    If it's a single static request/response, you should be able to configure a TCP send and receive string to monitor the ICAP servers. Does each server require a different Host header value? Or could you use a generic value for all of them? If the former, you could use a single TCP monitor. If the latter, you could potentially use a TCP monitor per server and assign that to the specific pool member.
    Aaron
  • Unfortunately, they require the host header. But, you gave me enough info to proceed thank you vary much.
    Regards,
    Pavlos
