iCall and external call
I wonder if anyone used iCall to trigger external call to another device - I guess that is right tool for the job, or maybe there is some better solution.
Scenario:
- ASM or DoS Protection is reporting violation (hope there is a way to extract IP of violation or IP from XFF)
- iCall is triggered (via log entry?)
- SSH or REST API call (via wget) is launched to report this IP to another device
- Another device is adding IP to black list and blocking traffic from this IP (this is of course outside F5 realm)
Piotr
- Henrik_Gyllkran
I think I would use a sideband connection in an iRule for this, I think it would be easy enough. The iRule can trigger on a violation event and send a request of your own design to the device.
- dragonflymr
Thanks for pointing to sideband. I wonder what is more performance friendly assuming thousands (20k+) TCP connections per second?
Piotr
- Henrik_Gyllkran
Hard to say, but I would guess sideband connections since iRules are handled by the TMM:s. I don't know exactly how iCall is implemented but since it's part of the management side of the BIG-IP and all management processes run outside of the TMM:s and thus have limited resources compared to TMM.
