asaleh2222_3098's avatar
asaleh2222_3098
Nov 21, 2017
IAPP citrix deployment problem
We need F5 to load balance Citrix servers for (XenAPP & VDI) Citrix environment contains storefront version 3.11.0.0.4 We need to make BIG-IP to authenticate citrix users using APM We tried using IAPP template () but not success when template executed we found this error text : script did not successfully complete: ("active-directory" unexpected argument while executing "tmsh::create [string range $args 7 end] " ("create" arm line 1) invoked from within "switch -exact -- [string range $args 0 5] { create { tmsh::create [string range $args 7 end] } modify { tmsh::modify [string r..." (procedure "iapp_conf" line 14) invoked from within "iapp_conf create apm aaa active-directory ${app}_aaa { admin-encrypted-password [expr { $allow_anonymous ? "none" : "[iapp_make_safe_password "$:..." invoked from within "subst $apm_aaa($new_aaa)" invoked from within "subst $pre_proc_map" invoked from within "if { $is_lb_scenario } { set apm_profiles "" set port $::webui_virtual__https_port subst $vs(web) if { $create_redir_vs } { su..." line:1652) Kindly Advice and if you have another template thanks to send it
