I am putting in generic non host based custom monitor for a pool and it doesn't work ?
When i use this as a custom node monitor it works and no issue. GET /Agile/default/login-cms.jsp HTTP/1.1\r\nHost: slhdalagilep01.adsprod.local\r\nConnection: Close\r\n\r\n if i use this as a monitor within a pool like so. GET /Filemgr/services/FileServer HTTP/1.1 it does not work. this will work : "GET /Filemgr/services/FileServer"
if i use this string on a host specific monitor entry : GET /Filemgr/services/FileServer HTTP/1.1\r\nHost: slhdalagilep01.adsprod.local\r\nConnection: Close\r\n\r\n it works if i use it this within a pool monitor it does not work : GET /Filemgr/services/FileServer
All response codes return 200 ok curl query : curl -lv curl -lv
I don't get it ... : What gives how can i make this work ?
- tlebouef_164239
The only thing i can see to do is on the pool level do generic port level monitor then on the node level then do a node based uri monitor.
