MarkM_63051's avatar
MarkM_63051
Jan 23, 2012
HTTPS Problem
Hello,
Up until now using the F5 has been fairly straight forward. Adding HTTPS certificate support for incoming IE connections however has got me stumped. I have watched the online webinar and tried many variations to get it working without success.
What I am trying to do is to take a working HTTP connection through the F5 to a pool consisting of a pair of Tomcat servers and convert the virtual server connection from HTTP to HTTPS. Wireshark traces show the F5 and the Tomcat communicating with each other and all of the status balls are green. How do I go about debugging my problem? Where do I look to find out what is not happening?
Regards,
Mark
  • Can the http Redirect Rewrite = ALL be built into an iRule? I need to create rules for my pools that use cookie persistance.
    http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/220/Rewriting-Redirects.aspx
  • Can the http Redirect Rewrite = ALL be built into an iRule?yes
    e.g.
    root@ve1100(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 172.28.19.252:443
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        rules {
            myrule
        snat automap
        vlans-disabled
    root@ve1100(Active)(/Common)(tmos) list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:8080 {
                address 200.200.200.101
    root@ve1100(Active)(/Common)(tmos) list ltm rule myrule
    ltm rule myrule {
        when HTTP_RESPONSE {
       if {[HTTP::is_redirect]} {
          HTTP::header replace Location [string map {"http://200.200.200.101:8080" "https://172.28.19.252"} [HTTP::header Location]]
    [root@ve1100:Active] config  curl -I http://200.200.200.101:8080/test
    HTTP/1.1 302 Found
    Date: Tue, 24 Jan 2012 23:17:46 GMT
    Server: Apache/2.2.3 (CentOS)
    Content-Type: text/html; charset=iso-8859-1
    [root@ve1100:Active] config  curl -Ik https://172.28.19.252/test
    HTTP/1.1 302 Found
    Date: Tue, 24 Jan 2012 23:17:57 GMT
