MarkM_63051
Jan 23, 2012HTTPS Problem
Hello,
Up until now using the F5 has been fairly straight forward. Adding HTTPS certificate support for incoming IE connections however has got me stumped. I have watched the online webinar and tried many variations to get it working without success.
What I am trying to do is to take a working HTTP connection through the F5 to a pool consisting of a pair of Tomcat servers and convert the virtual server connection from HTTP to HTTPS. Wireshark traces show the F5 and the Tomcat communicating with each other and all of the status balls are green. How do I go about debugging my problem? Where do I look to find out what is not happening?
Regards,
Mark
- MarkM_63051
root@f5-loadbalancer2(Active)(/Common)(tmos) show /ltm virtual SSLTest2
Ltm::Virtual Server: SSLTest2
Status
Availability : available
State : enabled
Reason : The virtual server is available
CMP : enabled
CMP Mode : all-cpus
Destination : 16.124.133.211:443
Traffic ClientSide Ephemeral General
Bits In 445.9K 0 -
Bits Out 1.1M 0 -
Packets In 508 0 -
Packets Out 481 0 -
Current Connections 0 0 -
Maximum Connections 4 0 -
Total Connections 72 0 -
Min Conn Duration/msec - - 143
Max Conn Duration/msec - - 26.2K
Mean Conn Duration/msec - - 4.5K T
otal Requests - - 0
CPU Usage Ratio (%)
Last 5 Seconds 0
Last 1 Minute 0
Last 5 Minutes 0
root@f5-loadbalancer2(Active)(/Common)(tmos) - nitass
Employee
tmsh list ltm virtual virtual_server_name
tmsh list ltm pool pool_name
curl -Ik https://16.124.133.211/
curl -I http://pool_member_ip/ - nathe
Cirrocumulus
Mark
Try all-properties at the end to get the configuration e.g. show /ltm virtual SSLTest2 all-properties
N - MarkM_63051
root@f5-loadbalancer2(Active)(/Common)(tmos) list /ltm pool
ltm pool SSLTEST {
members {
10.15.255.241:webcache {
address 10.15.255.241
session monitor-enabled
state up
monitor tcp
root@f5-loadbalancer2(Active)(/Common)(tmos) - MarkM_63051
[root@f5-loadbalancer2:Active] config curl -lk https://16.124.133.211/
Apache Tomcat It works on hap_tomcat1!
If you're seeing this page via a web browser, it means you've setup Tomcat successfully. Congratulations!
This is the default Tomcat home page. It can be found on the local filesystem at: /var/lib/tomcat6/webapps/ROOT/index.html
Tomcat6 veterans might be pleased to learn that this system instance of Tomcat is installed with CATALINA_HOME in /usr/share/tomcat6 and CATALINA_BASE in /var/lib/tomcat6, following the rules from /usr/share/doc/tomcat6-common/RUNNING.txt.gz.
You might consider installing the following packages, if you haven't already done so: tomcat6-docs:
This package installs a web application that allows to browse the Tomcat 6 documentation locally. Once installed, you can access it by clicking here. tomcat6-examples:
This package installs a web application that allows to access the Tomcat 6 Servlet and JSP examples. Once installed, you can access it by clicking here. tomcat6-admin: This package installs two web applications that can help managing this Tomcat instance. Once installed, you can access the manager webapp and the host-manager webapp.
NOTE: For security reasons, using the manager webapp is restricted to users with role "manager". The host-manager webapp is restricted to users with role "admin". Users are defined in /etc/tomcat6/tomcat-users.xml. [root@f5-loadbalancer2:Active] config - nathe
Cirrocumulus
Mark
To be sure - are you seeing monitor traffic and / or production traffic from the F5 to the tomcat server as both, I expect will be using port 80 so it may not be obvious. You may be seeing the client - f5 production traffic but no f5 - server production traffic, only monitor traffic. Hope I'm making sense.
What I always do here is tcpdump the client side interface and the server side interface at the same time, BUT seperately, and you should see a match up of the traffic (if it's working of course). You will see a tcp and seperate ssl handshake on 443 clientside and then tcp handshake on 80 on the serverside.
I presume you've not got a serverside ssl profile enabled on the virtual have you? You mentioned earlier the f5 will terminate the ssl connection so you won't need one.
As nitass requested a good look at your VS setup may help here.
N - MarkM_63051
[root@f5-loadbalancer2:Active] config curl -l http://10.15.255.241/
curl: (7) couldn't connect to host
Comments from Mark:
IP Address information:
IP Address of the Client/Browser: 15.253.58.161 (my PC)
IP Address of Virtual Server on the BIG-IP: 16.124.133.210
Self-IP of the BIG-IP: Mgmt IP = 16.124.134.131, internal = 10.15.255.246
IP Address of TomCat/Node: 10.15.255.241 - MarkM_63051
[root@f5-loadbalancer2:Active] config curl -I http://10.15.255.241/
[root@f5-loadbalancer2:Active] config - Mike_Maher
MarkM,
What is your Server Side SSL set to in your VS? If you are not doing SSL on the Tomcat servers then you need to make sure it is set to None. When you look at your client profile drop down to advanced and what options are you customizing?
To troubleshoot this you need to keep in mind that it is not all one connection. You have an SSL connection coming to the VS on the F5 that is terminating and then the F5 will do its own socket to the server. So you need to troubleshoot each side independently, I would personally start with the client side (client to VS) and rule it out first before looking at the server side (VS to Tomcat server).
Client Side troubleshoot:
Take a tcpdump on the F5 like Josh had stated, then run that through ssldump and see if the ssl handshake is completing successfully.
ex: ssldump -r external.pcap
If you want to decyrpt the session you will need to do this
ssldump -d -A -k /config/ssl/ssl.key/(the name of the key for your site) -r external.pcap
You basically want to confirm that the ssl handshake is completing and you see a GET request from the client.
Another tool to use to troubleshoot the client side would Fiddler or HTTPWatch plugins for IE for Firefox, they will show you what the browser sees.
From the server side, you keep saying you are seeing traffic in your wireshark trace, but what kind of traffic? Are you seeing a GET request to the web server? I ask because you should see traffic coming from the F5 in the form of whatever healthcheck you are doing on the pool to the web server, but that does not mean that it is actual client traffic.
This should work, as simply doing an SSL VS is not something that is uncommon on an F5 device, I run roughly a dozen of them on some ASM units I manage. - MarkM_63051
[root@f5-loadbalancer2:Active] config curl -Ik https://16.124.133.211/
HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
Accept-Ranges: bytes
ETag: W/"1901-1317214551000"
Last-Modified: Wed, 28 Sep 2011 12:55:51 GMT
Content-Type: text/html
Content-Length: 1901
Date: Tue, 24 Jan 2012 12:09:30 GMT
